I am not able the diagnose this problem. While the suv is running sometimes the hand brake light will turn on and if you apply the brakes then it sought off jams and makes noise. If you then stop the engine and start again, the light goes away and brake operates normal. This problem comes and goes away, bit I am not able to diagnose the problem. Fluid levels are good. Checked the rear brake and everything is functionally good.
Is this a problem of booster or some other hydraulic issue?
Mar 16, 2010 at 11:36 AM
