I have a vibration when it idles and when you first press the gas.
I had mounts replaced and the vibration showed up. The Nissan dealr said becasue I used After amrket mounts, they are stiffer than Nissaan mounts. So that is the problem.. When I took the car back to the Natiaonal CHain that i had the work done to they said it may be a pully. Either a harmonic balencer?? or A/c compressor, not mounts Is this possible
Feb 21, 2007 at 11:06 AM
