It takes a lot of cranking and then my car will start, if i very slowly apply the throttle it will rev all the way up but anytime i get on the throttle the car boggs down and wants to die and sometimes does, then a long cranking process to get it started again. changed fuel filter, pump, spark plugs, check distributor, injectors are clicking, pressure tested the fuel tested ok, cleaned air filter, cleaned and checked voltage at MAF sensor, checked compression 125 across all cylinders, checked for vaccum leaks none, checked all electrical connections dry and all connected, also cleared ECU and checked for codes all ok. after all of this car still wants to bogg down and die out any suggestions?
Oct 13, 2007 at 11:05 PM
