Intake gasket leak
NISSAN ALTIMA
SANJAYV
I own a Nissan Altima 01 with 30k miles on it.
Recently, i noticed some issue with the car when it started jumping between the gears and pulling forward when i pushed accelerator a little bit.
Went to check at local auto store, they said it was an intake gasket leaking. The part for that costs only 10-12 dollars but labor is around 600 dollars. I could not believe it? Is that true? Can it be so cumbersome just to change a gasket?
Secondly, i want to know if it is pretty unusual for a car with that low mileage to have a gasket leak (damage) just within 30k miles (~5 yrs old).
thanks in advance,
sanjay.
Feb 9, 2006 at 7:53 PM
MVANNESSJR
  • 223 POSTS
It's unusual, but not unheard of. The intake gasket replacement requires disassembling the intake manifold or intake header depending on which one has failed. I would call around for a few more estimates, but they may use a flat labor rate based on manufacturer recommended labor hours.
Feb 13, 2006 at 7:24 AM
FISHERMAN
  • 937 POSTS
How sure they are that the problem its that gasket?
do you still having warranty on your car?
ask for a second opinion, probably its just a vacuum leak or something else.
(600 reasons to look around :D )
Manuel.
Feb 14, 2006 at 9:05 AM
ASH2001
i had the same problem and i went for 90000 miles service and was told that intake manifold gasket needs to be replaced and they charged me $720 for labour for 8 hours and part was only for $24.Does it really take that long.
Feb 14, 2006 at 7:16 PM
FISHERMAN
  • 937 POSTS
waao!
Im at the wrong busisness!
:D
Feb 15, 2006 at 9:17 AM
