Clutch Nissan altima
NISSAN ALTIMA
ARIANEACK
Nissan Altima 2.4 GXE 1999, 120000 miles.
I am having trouble with the clutch. It initially started as a burning smell, which may or may not be related. Anyway, the mechanic 1 told me the clutch plate had worn out, and replaced it. Then, after a few months, the clutch would go to the floor too easily, and the gears would not shift. If I pumped the clutch, it seemed to regain some power. Clutch fluid level was low. Different mechanic 2 replaced slave cylinder.
Again same problem one year later, the clutch fluid was very dirty looking, but level was okay.mechanic 2 replaced master cylinder. A few weeks later, again same problem, clutch fluid level low now. What to do.
Mar 26, 2007 at 7:48 AM
2CARPRO JACK
  • 11,533 POSTS
Check the entire hydraulic line for leaks. Dont blame the tech's, your car has some miles on it and things that are related will do that
Mar 26, 2007 at 12:47 PM
