2006 Nissan Altima Car Jerks when on 10MPH, 40MPH, 60MPH
2006 NISSAN ALTIMA
38,000 MILES • 4 CYL • 2WD • AUTOMATIC
100MYA
Hi, My car jerks initially at 10MPH and that jerk is pretty much noticble and then the remaining jerks are not that bad at 40 and 60. I took it to the mechanic and they topped off the tranmission fluid and said there is nothing wrong. But i still get that problem. the only thing is the jerk goes away if the engine stays on for more than 30 mins. Please advice.
Mar 19, 2010 at 7:14 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 19, 2010 at 7:19 PM
