pcv valve location
2004 NISSAN ALTIMA
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARITZA
where is the pcv valve?
Mar 6, 2010 at 6:18 PM
LEGITIMATE007
  • 5,121 POSTS
look at the back of the intake manifold, there will be a hose coming out of the valve cover, the pcv valve will be connected to the hose at the valve cover or at the other end of it. Here is a diagram. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Mar 18, 2010 at 8:20 PM
SIDJO39
Where is the pcv valve on a '01 nissan altima located?
May 11, 2020 at 12:05 PM (Merged)
The PCV valve is situated at the drive belt side of the engine underneath the intake manifold
SIDJO39
Is it between the two () brackets?
RIVERMIKERAT
  • 6,110 POSTS
No The PCV valve is located on the other side of the engine. The image I have attached should help you locate it.
CARLELLIO
Where is the pcv located??
May 11, 2020 at 12:06 PM (Merged)
BLACKOP555
  • 10,386 POSTS
The most common location is in a rubber grommet in the valve cover. It can be installed in the middle of the hose connections, as well as installed directly in the intake manifold.
ISOM1998
Do I have to have the oil filter out to find it?
DRCRANKNWRENCH
  • 3,380 POSTS
The PCV valve is located either on or around the intake manifold or on the valve cover. You can trace a large vacuum hose thtat runs from the lower engine crankcase to the PCV valve and then to the intake manifold.
