2004 Nissan Altima CAR WILL TURN OVER BUT WILL NOT CRANK
2004 NISSAN ALTIMA
81,000 MILES • 4 CYL • FWD • AUTOMATIC
EBABYLOVET
MY CAR WILL TURN OVER BUT WILL NOT CRANK IT HAS BEEN VERY COLD ALL DAY SO I CANT FIGURE OUT WHATS WRONG PLEASE HELP ME WHAT COULD BE THE PROBLEM WHAT SHOULD I CHECK
Feb 12, 2010 at 10:14 PM
Do below to determiine if its fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 13, 2010 at 2:36 AM
