2003 Nissan Altima code p0345 cam shaft postion sensor
2003 NISSAN ALTIMA
79,899 MILES • 6 CYL • 2WD • AUTOMATIC
ABDOC44
Died while driveing threw a service eng code slip light came on but went off.pulled code p0345 cam sensor bank2
Jul 8, 2009 at 4:01 PM
RACEFAN966
  • 5,029 POSTS
Ok it looks like the cam sensor in bank 2 might be bad. So there is some tests to do so that can be determined. Now if the engine cranks over fine and just won't start then here is what you need to do. I have include it in a pic form so you will need to save it in your pictures and then magnify it and then let me know what you find it is broken up into two sets so I have included it in two pics ok. I think you will probably be replacing that sensor. Bank 2 is the front side as the engine sits side way's. Let me know how it goes.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_99.jpg
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic1_22.jpg
Jul 9, 2009 at 10:01 AM
