2003 Nissan Altima 2003 Nissan Altima
2003 NISSAN ALTIMA
93,000 MILES • 4 CYL • 2WD • AUTOMATIC
DANPM3
  • 5 POSTS
How come when my car is on and not moving the rpms are above zero and also when i drive the rpms are very high?
Jan 16, 2008 at 4:08 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The tachometer is an indication of engine revolutions per Minuit (R.P.M.) at idle the engine is only running very slowly so the rpm indicator is showing this. when driving the engine is running at a much faster speed, required to develop the power to drive the transmission, so the RPM's are registering higher.
Mark (mhpautos)
Jan 16, 2008 at 4:28 PM
DANPM3
  • 5 POSTS
[quote:943318ad1e="mhpautos"]Hi there,
Mark (mhpautos)[/quote:943318ad1e]
So what do i have to do to repair it, because the car is making some noise. Thank you for replying so promtly.
Jan 16, 2008 at 4:37 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I am not exactly sure about your problem, is it an engine noise that is your concern, can you supply a bit more detail please.
Mark (mhpautos)
Jan 16, 2008 at 4:50 PM
DANPM3
  • 5 POSTS
[quote:0c613b8785="mhpautos"]Hi there,
Mark (mhpautos)[/quote:0c613b8785]
When i drive my car it seems like the rpms are way to high and thats when the sound of the engine gets louder. Someone said it could a tube problem or a crack in the manafold
Jan 16, 2008 at 4:57 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Have the exhaust system checked for leaks, especially around the exhaust manifold and engine pipe. this can sound as if the engine is revving faster than it actually is. Start here first. A vacuum leak can cause the engine to idle faster than it should.
Mark (mhpautos)
Jan 16, 2008 at 5:05 PM
DANPM3
  • 5 POSTS
[quote:600af6ce12="mhpautos"]Hi there,
Mark (mhpautos)[/quote:600af6ce12]
Thank you so much, so i should just ask the guy to have the exaust system checked for leaks and all the tubes too.
Jan 16, 2008 at 5:25 PM
