2002 Nissan Altima Engine mount, valve cover gasket, head gasket
2002 NISSAN ALTIMA
MARZETA
2002 Nissan Altima 4 cyl Automatic 89,500 miles
My problem is so complex, ongoing and frustrating (to me), I'll give an overview of my problem in bullets.
Symptoms before initial diagnosis
- Rough idle
- Rough gear change
- Loud noise from engine area
- Engine overheating (frequent temperature guage fluctuation)
- Rapid loss of coolant
Initial Diagnosis
- Valve cover gasket problem
- Engine mount broken
- Complete fuel system cleaning needed
Repair costs: $600
Symptoms after initial diagnosis and repairs
- Lots of white smoke (never had this before)
- Problems starting (3 or more tries often necessary, never had this before either)
Secondary diagnosis
- Cylinder #1 misfire
- Head gasket problem, needs replacement
Estimated cost to repair: $2,100
Does this sound like a head gasket problem?
If yes, any estimates on reasonable repair costs? Can you recommend a particular service company?
If no, what problem do you think I have?
May 2, 2008 at 9:25 AM
LEGITIMATE007
  • 5,121 POSTS
yes, the latter half does sound like a head gasket problem, thats where all of theat white smoke is comming from coolant is going into the combustion chamber and getting burned, (rapid coolant loss). it could be worse you could have a cracked head. now as far as the price, you may want to get several opinions, especially on a diagnosis like that.
May 2, 2008 at 12:33 PM
MARZETA
Thank you.
I've looked online and I see that the blown head gasket issue is common in many 2002 Nissan Altimas. Are you aware if Nissan does anything to address this problem - since it's widespread?
May 3, 2008 at 7:50 PM
LEGITIMATE007
  • 5,121 POSTS
I will have to check the tecnical service bulletins or TSB. to see what they say .. Im sure they have some kind of info on this. each car ever made has TSB's. so I'll look it up and get back to you
May 3, 2008 at 9:50 PM
