2000 nissan altima door locks
2000 NISSAN ALTIMA
MO
HERE'S MY PROBLEM, I LOCKED MY KEYS IN THE CAR.SO I USED A SLIM JIM TO OPEN THE DOOR, NOW THE KEY WILL NOT UNLOCK THE DOOR FROM THE OUTSIDE. THE AUTOMATIC DOOR LOCKS WORK FROM THE INSIDE. SO I TOOK OFF THE DOOR PANEL, IT SEEMS THAT THERE IS A METAL BAR THAT IS NOT ATTACHED TO ANYTHING AT ONE END, AND THE OTHER END IS ATTACHED TO THE KEY LOCK.
WHERE DO I RECONNECT THE OTHER END SO THE KEY LOCK WILL WORK AGAIN.[/b]
Feb 19, 2006 at 12:49 PM
FISHERMAN
  • 937 POSTS
the only thig you can do its take the panel of from the other door and check where it goes.
should be a metal or plastic latch loose somewhere.
Feb 19, 2006 at 3:05 PM
