Once you have the manual, turn to page 1-17.
Adjustment - all models except the 2.5L engine.
Belt tension is adjusted by moving the idler pulley. To adjust the belt, loosen the lock nut (or adjuster) and turn the idler pulley adjusting bolt (usually on the bottom).
Replacement - all models except 2.5L engine
Loosen the drive belt adjustment bolt, slip the belt off the crankshaft pulley and remove it.
Remove the AC belt first to gain access to P/S, Alt, W/P belt. It is a very good idea to remove both belts at the same time.
Mark each belt and its appropriate pulley groove so the replacement belts can be installed in their proper position.
Feb 18, 2019 at 2:29 PM
(Merged)
