1998 Nissan Altima Ignition CON 1 Fuse blows
1998 NISSAN ALTIMA
195,000 MILES • 4 CYL • FWD • AUTOMATIC
SPUDW
  • 4 POSTS
The IGN CON 1 fuse in my panel continually is blowing. Engine stops & no contact to restart. All other Accessories OK. How do I track down the short?
Also, headlights and bright/dim are reversed.
Aug 5, 2009 at 10:17 AM
STEVEW84
  • 673 POSTS
What number fuse is it(not amps). Also, what is on that circuit?
Aug 5, 2009 at 12:47 PM
SPUDW
  • 4 POSTS
Hi Steve,
Thanks for your reply. There is no Fuse Number. It is 2nd row, 2nd from bottom between ABS and AIRB fuses. It is labeled IGN/CONT 1, so since everything else works, I assume nothing else is on the circuit.
(It is 10 amp)
Aug 5, 2009 at 2:39 PM
STEVEW84
  • 673 POSTS
My information resource does not give me it that way. Is this fuse inside the vehicle or under the hood? On your fuse cover it should give a number of location for that fuse. That is what I need.
Aug 5, 2009 at 3:54 PM
SPUDW
  • 4 POSTS
It was on the inside. Turns out mechanic installing radiator drilled hole in grill bracket that housed electrical cable and exposed cable. Bare wire was shorting on new bolt.
Thanks for your responses.
Aug 7, 2009 at 2:14 PM
