1998 Nissan Altima Headlight problem
1998 NISSAN ALTIMA
KEVINNC43
Electrical problem
1998 Nissan Altima 4 cyl Front Wheel Drive Automatic
I have a 1998 Nissan Altima.Low beams ,turn signals,corner lights all work but when I switch to high beams no lights at all.I put new switch in but same problem.New bulbs added too.
Feb 25, 2009 at 1:18 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me if your model is a GLE, GXE, SE, or XE. Also your engine size in liter.
Feb 25, 2009 at 7:41 AM
KEVINNC43
1998 GXE 2.4 4 cylinder
Feb 26, 2009 at 6:27 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for getting back with me.
Do you have Daylight running lamps?
Check fuses 32 and 33 with an ohm meter to make sure they are good.
Please check the Theft Warning Lamp Relay located in the relay box, right side of engine compartment. See if there is another relay that is the same…..swap them and see if they work then.
Feb 26, 2009 at 7:03 PM
