blower resistor location for replacement
1998 NISSAN ALTIMA
ROSE DAVIS
What would cause the blower for AC to work only on the 4th speed...the highest speed. Lower speeds do not work at all.
Aug 9, 2009 at 12:00 PM
AAP34798
  • 16 POSTS
the usual problem when ac air or heat doesn't flow from the vents even when turned on is a bad blower motor resistor. also, when bad, the switches will start to not work in lower settings and the higher will continue to work most likely because of a thicker coil for a higher control setting that hasn't been burnt out. the pics are that of an altima but are typical of the flocks. naturally the resistor is located next to the blower motor, under the glove compartment, and held by 2 bolts. they are easy and cheap to replace and can be gotten cheapest by rockauto.com
https://www.2carpros.com/forum/automotive_pictures/400521_082509_19102_2.jpg
https://www.2carpros.com/forum/automotive_pictures/400521_082509_19171_2.jpg
https://www.2carpros.com/forum/automotive_pictures/400521_082509_19141_4.jpg
Aug 25, 2009 at 8:01 PM
DVIZZOCA
My sons Altima heater fan only runs on highest speed. Also does the same for A/C. Any ideas? OK thanks, but how do I locate the blower motor housing?
May 25, 2021 at 11:20 AM (Merged)
KNIGHTRIDERKITT2000
  • 93 POSTS
https://www.2carpros.com/forum/automotive_pictures/13857_R2032177349OES_2.jpg
this should be what your looking for, should be on or near blower motor housing
