how do you remove 100 amp fuse. it will not pull out. is there a bolt or screws holding it in, if so how do you get to the bolt or screw
Jan 25, 2008 at 6:39 PM
2CARPRO JACK
CERTIFIED EXPERT
If not visible from the top, may have top remove the power block and take the bottom off it to access the screws
Jan 26, 2008 at 8:08 AM
JACK JENNINGS
MEMBER
Gee, when you want help, you only get the run around. To remove this fuse, you have 2 clips below both side on the side that have a screw that will have to be removed before you can pull the fuse.
