1997 Nissan Altima Water Pump
1997 NISSAN ALTIMA
PETEASANCHEZ
I have a Nissan Altiima that needs it's water pump replaced, it's 10 years old, has 147 plus miles on it. Is it worthwhile to replace the water pump. It's going to cost me 498 dollars to get this done. Thoughts guys???
Jul 13, 2007 at 8:54 AM
ANUBIS679
  • 11 POSTS
[quote:c0cf3db371="peteasanchez"]I have a Nissan Altiima that needs it's water pump replaced, it's 10 years old, has 147 plus miles on it. Is it worthwhile to replace the water pump. It's going to cost me 498 dollars to get this done. Thoughts guys???[/quote:c0cf3db371]
Its worth it because the cost of getting another vehicle is much more.
I have a 96 Maxima with 140k miles on it. I had the water pump and thermostat replaced and it cost well over 800 dollars due to the fact that the Maxima's water pump is nestled between 3 timing chains. You have to remove a plate that has 30+ screws in it that have to be tightened in a sequential order. Took the mechanic 6hrs to do this.
Hopefully your not driving the car with the bad water pump because you could cause serious engine damage to your car if it overheats. I.E.: Blown head gaskets and warped heads; easily costing well over 600 dollars to fix. Luckily u have a 4 cylinder so its not so bad.
Jul 19, 2007 at 10:39 PM
