Electrical problem
1997 Nissan Altima 4 cyl Front Wheel Drive
my wife's 97 altima gxe recently had some flood damage. Did not get into the engine but did reach high enough inside to submerge the ecu(behind the center console behind the radio). The car was completley dead and replaced the battery. As soon as the new battery was hooked up the radiator fans kicked on and run continuesly? Brake lights and other lights work. car will fire but will not start. Can you point me in the right direction as far as process of emlination to fix the fan problem as well as getting it started. Is there a way to test the ecu? Also after water had gone down the car did start and idle fine, put in reverse, then in drive and died. went to start it again and battery was dead. thinking maybe the fan killed the battery? something arcing in the fuses? please help!!!!!!
Aug 11, 2009 at 1:59 PM
