1997 Nissan Altima how to remove the factory radio
1997 NISSAN ALTIMA
MEGANN54
Electrical problem
1997 Nissan Altima 6 cyl Automatic
i cant figure out how to remove the radio i cant find all the places to unscrew things or anything.
Jul 7, 2009 at 1:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation! The radio is attached to the trim plate by several screws installed from the rear
https://www.2carpros.com/forum/automotive_pictures/261618_1_78.jpg
Disconnect the negative battery cable. Remove the dashboard trim panel that surrounds the radio. Remove the four screws securing the radio. Carefully pull the radio from the dashboard. Label and disconnect the electrical harnesses and antenna wire. Remove the radio from the vehicle. To install: Connect the electrical harnesses and antenna wire. Carefully position the radio in the dashboard. Install the four radio attaching screws and tighten securely. Install the trim panel that surrounds the radio. Connect the negative battery cable.
Jul 7, 2009 at 2:14 PM
