1997 Nissan Altima blowing the meter fuse
1997 NISSAN ALTIMA
140,000 MILES • 4 CYL • FWD • AUTOMATIC
ANITAKAY
My meter fuse keeps blowing. when it does the instrument panel quits working and the alternator does not charge the battery. I thought that the Alternator might have had a short in it so I replaced it and it did not help...What might be causing this?
Dec 28, 2007 at 5:11 PM
MHPAUTOS
  • 31,937 POSTS
You may have a problem with the circuit board on the back of the instrument cluster. This will be rather tricky to track down, the best thing to try is to get hold of a cluster and plug it in, if the fuse is ok, problem solved if it blows, the problem is in the loom.
Mark (mhpautos)
Dec 29, 2007 at 12:44 AM
