[quote:54c53c4b53="jazzy702"]1997 4 cyl Two Wheel Drive Automatic 80000 miles
how do you remove pulley my manual says wedge screwdriver in flywheel.
but i can't find access[/quote:54c53c4b53]
To removed the Crank Shaft Bolt you will need a 3/4" impact wrench to remove it. Check your local rental store. Ask for an electric one. I have found this the easiest way to remove the bolt.
Aug 17, 2008 at 4:10 PM
