1996 Nissan Altima windshield wiper fluid not squirting
1996 NISSAN ALTIMA
120,000 MILES • 4 CYL • FWD • AUTOMATIC
MUMBLY79
both of the sprayers have stopped spraying wiper fluid on my windshield (both stopped at the same time as far as I can remember). I tried to clean them out with a pin, but this did not help.
Please let me know what the possible solution/s might be and, if at all possible, send me diagrams of the vehicle that show me what to do. Thank you very much!
Nate
Dec 25, 2007 at 4:30 PM
SERVICE WRITER
  • 9,123 POSTS
Check for power getting to the pump, do you hear it run at all? Take some compressed air or try to blow through the rubber hose that leads to the squirts from the pump to see if it is restricted.
https://www.2carpros.com/forum/automotive_pictures/30961_wiper_1.jpg
Dec 25, 2007 at 7:29 PM
MERLIN2021
  • 17,250 POSTS
I have no diagrams, but, check for a blown fuse, if no blown fuses, the washer pump may need replacing, unplug the connector, have someone activate the pump, and test for voltage at the connector, if there is voltage replace the pump.
Dec 25, 2007 at 7:31 PM
MUMBLY79
Thank you. I'll check this out.
Dec 26, 2007 at 5:54 PM
