DTC P0505 - IDLE AIR CONTROL VALVE - AUXILIARY AIR CONTROL (IACV-AAC)
Check Power Supply
Turn ignition switch to OFF position. Disconnect IACV-AAC harness connector. Turn ignition switch to ON position. Using a voltmeter, measure voltage between IACV-AAC harness connector terminal "c" (Yellow wire) and ground. If battery voltage does not exist, repair fault in Yellow wire and check fuse No. 4 in fuse block. If battery voltage exists, go to next step.
Check Output Signal Circuit
Disconnect ECM harness connector.
Check continuity between ECM harness connector terminal No. 101 and IACV-AAC harness connector terminal "d" (Blue wire).
If no continuity exists, repair open in Blue wire.
If continuity exists, go to next step.
Check Component
Inspect IACV-AAC valve.
Replace IACV-AAC valve as required.
Disconnect and reconnect harness connectors in circuit and perform FINAL CHECK.
Jun 13, 2010 at 9:37 PM
