REPLACEMENT
1. Remove front cover. Refer to Timing Chain. See: Timing Chain\Service and Repair
2. Remove oil pump cover.
3. Reverse procedure to install, noting the following:
* Always replace oil seals and gaskets with new ones.
* When installing oil pump, apply engine oil to inner and outer gears.
* Use a scraper to remove old liquid gasket from mating surface of front cover and cylinder block.
Jan 20, 2010 at 4:11 PM
