1994 Nissan Altima tranny or electrical
1994 NISSAN ALTIMA
362,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEDDY025
my nissan will be fine to drive for about 10 minutes, then it will lose all the gears. I can move the gear shifter and it won't go into anything, and will just sit there and rev up. If i shut the car off, it will go again when it restarts, but only for a little distance and then will do the same thing again. It seems like the warmer the car, the less distance it will travel. but whenever it is shut off, it will always go again. I have had the tranny filter cleaned and changed the fluid twice aready. Any idea what this is before i go to the garage???
Feb 16, 2009 at 12:29 PM
The computer uses the throttle position and vehicle speed sensors input signals to command the transmission solenoids to upshift/downshift/lock-up/ovedrive etc if they're okay -You have an internal problem with the transmission. Get it pressure tested to find out
Feb 16, 2009 at 12:40 PM
KEDDY025
thanks. that sounds like what it is compared to some other things i have got in responce,
Feb 16, 2009 at 12:41 PM
