1994 Nissan Altima low oil pressure
1994 NISSAN ALTIMA
235,000 MILES • 4 CYL • FWD • AUTOMATIC
CRWALKER18
We replaced entire timing set. Did not prime oil pump. After reassembly,car runs well but oil pressure light only goes off at high RPM. Tried to prime pump thru oil filter hole. Light finally went off after priming oil thru oil pressure sensing unit. Started car several times and drove it home with no difficulty. Upon restarting car, oil light is on again. How can we prime pump so it stays primed?
Dec 31, 2007 at 7:12 PM
MHPAUTOS
  • 31,937 POSTS
If the pump is primed it will stay primed unless there is an air leak in the pump seal or gasket, First thing i would do is have a pressure test cold with a master gauge, just in case the sender is giving a false reading.
Mark (mhpautos)
Jan 1, 2008 at 12:44 AM
