1994 Nissan Altima Distributor
1994 NISSAN ALTIMA
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
DWJAK
I have a '94 Nissan Altima, I bought it at the auction and am now stuck with it. I took it to the dealer to assess everything wrong with it & they said that the distributor is leaking oil, and that the power steering hose needed replaced (as well as a power steering flush). Could either of these cause the check engine light to periodically come on? I have also been experiancing some rough idling, and difficulty putting the car into drive occasionally........what should I be worried about?
Thanks!
May 2, 2008 at 1:07 AM
MASTERTECHTIM
  • 4,750 POSTS
the distributor could cause the check engine light to come and and rough running. not going into gear can be caused by a bad brake light switch if the shifter doesnt move. if the shifter goes into drive but car still wont move then there is a problem with the transmisssion.
May 2, 2008 at 6:00 AM
