1993 Nissan Altima Fuel pump Failure
1993 NISSAN ALTIMA
360,000 MILES • 4 CYL • FWD • AUTOMATIC
DUSTDEVIL
Hi guys, I just had the fuel pump go out on my 93 Altima and I want to replace it with an external pump and wire it into the factory wiring. My question is, how many gallons per minute does the factory pump put out? I want to match the output with the aftermarket pump cause I just can't afford to replace the intank pump. I need this answer ASAP cause I'm stranded out of town and have to get home to work by Monday night. Thanks in advance!
Aug 29, 2010 at 11:45 PM
Dunno the GPM but make sure it can do below
Fuel Pressure With Regulator Vacuum Hose Connected 235 kPa (34 psi)
With Regulator Vacuum Hose Disconnected 294 kPa (43 psi)
Aug 30, 2010 at 2:34 AM
DUSTDEVIL
Thanks for the info, this will help in choosing the right pump.
Aug 30, 2010 at 9:15 AM
