1991 Nissan 300ZX 6 cyl Two Wheel Drive Automatic unknow miles
hello i have a 300zx with idle problem the past 2 months i have been having idles problem. i have replaced alot of stuff and can found out what it is. the parts that i have replaced is the fuel pump, fuel filter and fuel regulator, IACV, and all the hoses to it. i have replaced all spark plugs and yes they are factor. both PVC values and the PVC hoses. all vacuum tubes. i have a data scan i can turn of each cylinder but you can tell that each cylinder is firing i have ohm tested injectors and coil packs and power tested the connectors i getting no fault codes. i can hear injectors ticking i have cleaned out intakes and air filters. this is whats happen the car takes along time to start after sitting for awhile i have to crank it 2 times to get it to start. car drives fine has hesitation but its common with these cars car will idle fine but when i come to a complete stop it bogs down and surges and dies i have to put my foot on the gas to keep it idling if the car is costing in idle it will not stall but as soon as it stops it idles and bogs down and surges and slowly stalls. the funny thing is that as soon as i get where im going put it in park and feather the gas it will idle fine. it doesn't happen all the time but it happens alot
Jul 26, 2010 at 11:43 PM
