1990 Nissan 300ZX clutch
1990 NISSAN 300ZX
150,000 MILES • 6 CYL • 2WD • MANUAL
SONNYBABY05
i am having a problem with my clutch, there was a loss of ressure in my clutch pedal. I am trying to bleed the clutch and cannot see a positive change. After unscrewing the bleeder screw and pumping the clutch pedal, fluid ran through the line however, i felt no difference in pressure as I pumed the pedal
Nov 26, 2009 at 1:08 PM
Z32BRYAN
  • 16 POSTS
[quote:861ad7714b="sonnybaby05"]1990 Nissan 300ZX 6 cyl Two Wheel Drive Manual 150000 miles
i am having a problem with my clutch, there was a loss of ressure in my clutch pedal. I am trying to bleed the clutch and cannot see a positive change. After unscrewing the bleeder screw and pumping the clutch pedal, fluid ran through the line however, i felt no difference in pressure as I pumed the pedal[/quote:861ad7714b]
there is a second bleeder valve on the car, its in the engine bay 6 inches away from your passenger headlight, there is a way to cancel it out but it takes some work
Apr 9, 2010 at 2:15 PM
