1984 Nissan 300ZX Heater, brake lights
1984 NISSAN 300ZX
18,400 MILES • V8 • 2WD • AUTOMATIC
MIKEMAUREEN
Trying to find out how to troubleshoot the brake lights that go in and out and the heater that doesn't work. This is a turbo and maybe I can check the heater core? But where is it?
Jan 19, 2009 at 1:13 PM
MIKE H R
  • 3,094 POSTS
with reference to the brake lights, check the brake light switch, it is mounted on the pedal itself. with reference to the heater. there are two rubber lines that go into the fire wall. check to see if they get warm or hot. if not then there could be a couple of things , first the thermastat otr the heater core is clogged. If the heater core is blocked you may be able to back flush the core without taking it off the car. they have back flush kits available at most auto stores.
Jan 21, 2009 at 9:37 AM
