Changing water pump
NISSAN 240SX
AMEH29067
1997 Nissan 200 SX SE with 166000 miles. Water pump is leaking. How do you change the water pump. I cannot locate a repair manual.
May 6, 2006 at 7:31 PM
CBAILEYII
  • 26 POSTS
More often than not, this is going to be one of those that you really should have done at the shop. Best practice is to have the timing belt replaced at the same time since they require the removeal of many of the same time consuming parts. Not the easiest thing to do in most DIY scenarios.
May 8, 2006 at 12:29 AM
