I have a '92 Nissan 240sx and the clutch is stuck in the down position. You can pull it up but when you press on it it immediately snaps back down and stays down. I had noticed that the clutch seemed to be "sticking"
a bit when shifting, prior to this. And sometimes the car has been hard to shift into 1st and reverse. I tried adding clutch fluid but the clutch is still stuck down. Is this going to be expensive to fix or is it not a big deal? Thanks.
-M45
-M45
Jan 6, 2007 at 9:43 PM
