89 240sx tons of white smoke and no throtle response
1989 NISSAN 240SX
TOLENTOS13
what could the problem be for this i need lots of help now that i dont know what else to do because i changed the timing chain with the guides. i also changed all the head gaskets, and the injectors and the compression on each cylinder its 185 so i dont know what else to do please could some body get me some feed back?
Nov 17, 2007 at 10:09 AM
MERLIN2021
  • 17,250 POSTS
Check the fuel pressure regulator, pull the vacuum line off and see if there is any gas in it, if so change that and your oil! Gas will be present in the oil pan!
Nov 17, 2007 at 2:45 PM
