Engine Mechanical problem
1995 Nissan 240SX 4 cyl Two Wheel Drive Automatic
I blew a valve cover gasket and had it repaired. They test drove it and after about an hour of run-time, the NEW gasket blew out also. They said that the pressure in the engine was too high and they couldn't figure out why without taking the motor apart. Is this a common problem? Is there something they might have overlooked that could be causing the excess pressure build-up, or should I start looking at buying a new motor/car altogether?
Mar 18, 2009 at 7:00 PM
