1993 Nissan 240SX No Spark from Coil
1993 NISSAN 240SX
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICKPASS
I was driving the other day and car just stopped running.
Enging turns over plenty of gas, but no spark comming from the Coil. Does anyone know anything about this.?
I changed the Coil also. Still no spark. Please help.
Rick
Jan 17, 2008 at 3:20 PM
Check for battery voltage at the positive terminal of the coil-not there check for an ignition relay/fuse. Okay there -could be the crank angle sensor in the distributor-the fix is replacement. CAS checks out could be the computer not switching the primary circuit of the igniton system causing the coil not to fire the plugs
Jan 17, 2008 at 4:44 PM
