1992 Nissan 240SX Overnight drain
1992 NISSAN 240SX
241,000 MILES • 4 CYL • 2WD • MANUAL
RODNEYRC
I have a battery killing drain in my 240. I've had the alternator replaced and have went through at least 3 batteries (thank goodness for Costco & Walmart) When I put my meter between the negetive post and the ground lead I get a -400ma reading that disappears to O when the fusible link to the alternator is disconnected. On the electrical schematic it looks as if the alternator is the only thing on the line and I've already had that replaced. Where do I go from here?
Oct 15, 2008 at 12:24 PM
2CARPRO JACK
  • 11,533 POSTS
teh bulb check relay is also tied into that circuit via the alt. try removing that relay and see what happens, it is in the fuse/relay block left side of instrument panel
Oct 15, 2008 at 5:50 PM
