Well, when I was driving my rpm started going up and down. I pulled over on the highway, popped my hood to check. Man, the engine started shaking pretty hard and then it died. Started checking everything. Waited thirty minutes and cranked it and started up fine untill it was warmed up for like a minute or two then rpm went up and down again and died. I thought it was my MAF sensor because it did have some missfire, my temp. coolant sensor too. Still the same. Have new ngk plugs and new stock wires. Tried a vaccuum leak cheak, none leaking. Now I'm thinking about the ignition coil. Haven't tried yet, because it's new. Might have to check the voltage I guess. So if you can help me out, thanks. Don't want to spend money on what is still working fine.
Dec 4, 2008 at 2:07 PM
