HI, MY PROBLEM STARTED LIKE 1 1/2 YEARS AGO WHEN I REPLACED BOTH CLUTCH MASTER AND SLAVE CYLINDER. EVERSINCE THAT DAY I COULDN'T GET STABLE PRESSURE ON MY CLUTCH WHEN YOU DEPRESS IT. I KEEP GOING BACK TO THE MECHANIC TO BLEED IT AGAIN & AGAIN BUT STILL THE SAME RESULT. I KEEP DRIVING MY CAR WITH THAT CLUTCH CONDITION FOR 1 1/2 YEARS THEN ABOUT 2 MONTHS AGO MY CLUTH FAILED TOTALLY SO WE REPLACED THE WHOLE SET. THEN AFTER A WHILE I FELT A DIFFERENT CLUTH PRESSURE EVERYTIME I USE MY CAR. THEN ABOUT 2 WEEKS AGO ON MY WAY TO WORK I KNEW SOMETHING IS TERRIBLY WRONG BECAUSE DEPRESSING THE CLUTCH PEDAL IS REALLY A BATTLE. IT GETS REALLY HARD TO DEPRESS. ALSO I NOTICED THAT AT THE 4TH SPEED I COULDN'T GET ANY FASTER THAN 40MPH. IT FEELS LIKE THE CLUTCH IS ENGAGE BUT THEN IT'S NOT. YOU KNOW. IT FEELS LIKE TRYING TO SPEED UP YOUR CAR ON NEUTRAL. THEN I SMELL THIS BURNING SMELL. SO I GOT TO WORK OK. BUT WHEN IT'S TIME TO GO HOME I FOUND THAT I HAVE NO PRESSURE ON MY CLUTCH AT ALL. I TRIED TO PUMP IT BUT TO NO AVAIL. SO I HAD IT TOWED THEN THE MECHANIC ( DIFFERENT FROM THE FIRST ONE) REPLACED BOTH MASTER AND SLAVE CYLINDER. WELL, IT TURN OUT OK FOR A WHILE THEN I STARTED FEELING DIFFERENT CLUTCH PRESSURE AGAIN EVERYTIME I DRIVE MY CAR. THERE ARE TIMES WHERE I FEEL A FREE PLAY ON THE CLUTCH PEDAL AND SOMETIMES NONE AT ALL. I DONT REALLY KNOW WHAT'S GOING ON. PLEASE GIVE ME SOME ADVISE ON WHAT TO DO AND WHAT TO CHECK. THANKS IN ADVANCE.
Jul 3, 2008 at 7:32 PM
