1989 Nissan 240SX rear brakes locked
1989 NISSAN 240SX
BADCARLUCK
Brakes problem
1989 Nissan 240SX 4 cyl Two Wheel Drive Manual
i lost brakes, replaced master cylinder, now my rear brakes are semi locked-up. it's all around discs,non-abs, i bled them and for a few miles they were ok, then i felt them slowing me down and when i stopped and checked, smelled them burning. i don't know what it is.
Jun 23, 2009 at 10:58 PM
DRAGGING BRAKES
May create a steering pull and/or increased fuel consumption. Caused by weak or broken retracting springs on drum brakes, a jammed or corroded caliper piston, a floating caliper with badly corroded mounting pins or bushings (uneven pad wear between the inner and outer pads is a clue here), overextended drum brake self-adjusters or a sticky or frozen emergency brake cable.
Jun 24, 2009 at 3:35 AM
