1998 Nissan 200SX brake and battery lights on
1998 NISSAN 200SX
EDEAN2019
Brakes problem
1998 Nissan 200SX 4 cyl Two Wheel Drive Automatic
The battery light is on and the car still starts and runs quietly. the brake light is on and the brake is all the way down.
Sep 23, 2010 at 5:55 PM
Have the charging system checked to rule out the alternator-also for the brake light-try adjusting the parking brake switch and check the brake master cylinder fluid level
Sep 23, 2010 at 6:11 PM
KENEKE
  • 4 POSTS
The brake pedal is barely touching the two switches and there's a hole in the pedal where it supposed meet the switch. Are there supposed to be nylon or rubber grommets that insert in the holes on the pedal itself?
Apr 15, 2011 at 8:19 AM
