1996 Nissan 200SX No fire to spark plugs
1996 NISSAN 200SX
DELVISDIAZ
Electrical problem
1996 Nissan 200SX 4 cyl Front Wheel Drive Manual 150m miles
I try to start the car. The engine turns but does not get fire to the plugs. Fuel pump is working and the battery is charged.
Nov 1, 2009 at 6:20 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 2, 2009 at 4:32 AM
GMAN96
  • 7 POSTS
Check & REMOVE DISTRIBUTOR CAP ITS COMMON FOR ROTOR NUT HELD ON BY A 9 OR 10 MM NUT TO WEAR & ROTOR BECOMES LOOSE CAUSING NO SPARK
Oct 14, 2022 at 10:15 PM
