1980 Nissan 200SX car starts no internal electrics
1980 NISSAN 200SX
90,000 MILES • 4 CYL • 2WD • MANUAL
BOOROCKET
it just recently started snowing and i went to go start my engine to warm the car up to drive home, everything electric works with the engine off and the key turned heater radio and all that jazz .but when i turn the engine on everything doesnt want to work anymore, the only thing i can get to come on is the head lamps. could it be the battery is cold? the car sat for 3 hours in the snow before i started it again.
and another note my fuel gauge doesnt read, i know i have a full tank of gas but it still reads Empty
please help
Nov 9, 2009 at 3:49 AM
Lets get that battery load tested and double check connection then report back
Nov 9, 2009 at 10:53 AM
BOOROCKET
[quote:e8bc42b2bd="rasmataz"]Lets get that battery load tested and double check connection then report back[/quote:e8bc42b2bd]
the problem fixed itself somehow and replaced itself with another problem
the car will idle for five to ten minutes then die. when i try to crank it back up it tries to turn over then starts clicking it will fail to start for about ten minutes i was told by a friend that it might be my MAF sensor would that be the cause?
Nov 9, 2009 at 7:37 PM
To rule out a weak fuel pump hook up a fuel pressure gauge and monitor it within that time frame-also when it dies out-do below immediatley to catch it if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 9, 2009 at 7:45 PM
