Car is making a tapping/light clunking noise that didn't make before I just got $1,000 work done. Happens when I take foot off gas it's a "light tapping / clunking" like a noise, sound and volume, between tapping a tin can and a cow bell noise. It occurs intermittently when I decelerate / release gas pedal.
Per the service description this is what they did: Front drive axles outer CV boots torn. Installed 2 reconditioned front drive axles / all other parts are new. Found PC Valve, coolant hose to water pump is bad. Replaced water hose and PCV valve. Also replaced coolant. Replace timing belt and water pump. Found over engine valve leaking, installed new valve cover gasket. found power steering pressure hose leaking. installed new pressure hose. All parts new except front drive axles.
Jan 26, 2015 at 1:58 PM
