Did you bench bleed the brake master before installing it? If not, this needs to be done. Please check out the video below.
https://youtu.be/WDxvEQrMkBg
This guide can help as well:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
If the brake master was bled, then you have air stuck in the ABS unit so the valves inside the unit will need to be held open while you bleed the system. Please check out this video to show you how:
https://youtu.be/nQRnKyVyMuQ
Please let me know how it goes.
Feb 20, 2023 at 12:24 PM
