The relearn for the crankshaft position sensor wouldn't cause this. If you still have spark when the engine stalls, we have a fuel-related issue.
When this happens, have you ever noticed dark smoke from the exhaust or a fuel smell? Also, have you checked your fuel pressure to make sure it isn't too high or too low? If it is too high, it could flood. The idea that you need to pump the throttle could indicate this type of issue. When you press the pedal to the floor, it shuts down fuel injection to eliminate flooding. When you indicated pumping it, that thought came to mind.
Here is a link that explains how to test fuel pressure. Consider doing this.
Also, there is a vacuum hose to the fuel pressure regulator. Disconnect it and check to see if there is fuel in it. If there is, the diaphragm in the regulator is bad.
Let me know what is found.
May 29, 2022 at 8:40 PM
