I apply light pressure around 20 mph I hear a rubbing as if the rotors not true?
2015 CHEVROLET IMPALA
52,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
KMSYR
Just had brakes done when I apply light pressure around 20 mph I hear a rubbing as if the rotors not true. I opened the window and hear a definite rattling noise. On my way to get the parts can you help me?
Mar 27, 2019 at 12:39 PM
More then likely they just need to be replaced. I would suggest removing the wheels and inspecting the brakes.
Here is a guide that will help with replacing them as I suspect they are going to need to be replaced:
Below is the process on how to replace the pads and rotors on this vehicle.
Let's run through this material and let us know if you have questions. Thanks
Mar 3, 2021 at 8:22 AM
