Will not crank after replacing battery, starter and fuses
1995 PLYMOUTH VOYAGER
126,797 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
Just replaced the battery the starter and fuses all brand new parts. It has plenty of juice you can even hear the fuel pump engage. When you turn the key to crank there is nothing at all. Have even started it by bypassing the solenoid, that is the only way it cranks over to start. Any ideas what the problem is?
Oct 15, 2016 at 1:23 PM
HMAC300
  • 48,601 POSTS
scan for codes and do wiggle test on crank sensor if it starts the harness needs to be replaced. check asd relay in power distributor box change with a like relay.
Oct 15, 2016 at 4:00 PM
RENEE L
  • 1,260 POSTS
Hello [email protected],
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Oct 15, 2016 at 4:35 PM
