Neutral safety switch on transmission
1993 NISSAN SENTRA
355,000 MILES • 4 CYL • 2WD • MANUAL
MS LOVE
I am having problems with the safety switch that the clutch engages to allow the vehicle to crank. I have to push in the clutch several times and sometimes even then it does not want to crank. I know I need a clutch pretty soon but I have not had any problems with the clutch. Someone told me about the safety switch and how to change it or bypass the wires. I came here to see how to do it.
Jan 21, 2018 at 7:31 AM
Good afternoon. the switch is under the dash attached to the clutch pedal. it has two wires that attaches to it. you can remove the connector and use a paper clip to bypass it. I would only use that as a test. if it works, just get a new switch and replace it.
Jan 21, 2018 at 10:01 AM
MS LOVE
I think I found it. Thank you.
Jan 21, 2018 at 5:04 PM
You are welcome. Thank you for visiting 2CarPros.
Jan 21, 2018 at 5:10 PM
